Wanted Middle TN- split case for fj60, part or whole.
Middle TN
As stated, I need the rear case half or a whole split case for my FJ60. Mine is cracked, and failure is imminent. I'm not wealthy or proud, will accept charity, haha. Just need to fix my ride.
Pm here or call/text 73one-42O-13fortyseven.
you should post what size he idler shaft is, so you get the correct replacement.
/this\
I might have something, but wouldn’t know if it would fit without that critical measurement.
I bought a split case cheap many years ago that got chewed up on the inside by failed idler bearings, but the case didn’t crack.
My current case is a 34 mm, but I can also use the 38mm case because I'm using an nv4500 with an advance adapters kit that uses an intermediate spud shaft instead of the huge output shaft from the old 4 speed.
if the back half of the case is for a 38mm idler, the front half needs to be also.
I have a 34mm back half I’m not using
