Metals question - yeah, it's a dumb one....
Idaho
I have a length of 1/4 x 6 inch plate that I can't remember where it came from.
It kinda looks like stainless, kinda shiny and all. But, I would have never knowingly bought stainless.
So, my question is how can I tell if it's stainless steel or regular steel?
It is magnetic, but my web searching has revealed that the magnet test isn't definitive.
Any help?
Thanks,
Phil
A little salt water might tell you.
-Spike
Rust is probably the only way...
Since it's relatively dry here in Gilroy, I'll have to use an accelerant. Thanks for the salt-water suggestion.
Phil
Spark test... How would you do that?
Phil
Grind on the metal with a bench grinder or side grinder and watch the sparks.
Different metals give off different "signature" patterns of spark patterns and colors.
Question, why do you care?
Fair question :D
I want to use it for a t-case mounting plate and frame mounting plates for my cross-member/skidplate. Other parts will definitely be regular steel so I was somewhat concerned about welding two different types of steel together. If it is SS.
If I can weld the two with standard gas shielded MIG wire, then the whole question is indeed moot.
Using the grinder did not even occur to me... :doh:
Phil
who cares x2 .... justweldit .... you can weld stainlless with a mig ! the weld wire will rust.. thats it ... sounds like you got a piece of 1018 tool steel ?
:cool: I will justweldit :D
Could be tool steel I suppose. It has no markings or painted end. Is definitely different than the other plate I typically use. But it just isn't quite like the other pieces of SS I've seen.
I'll post up some results after I play with it this weekend.
Phil
yep, stainless glues to mild just fine.
Really?
I have a 260-300lb chunk of 440 Stainless that has been machined to look like an drive axle.
Do a springover on it :D
It could be a magnetic stainless. What color is the bar? Is it light grey or dark? Does it have really sharp corners? I have my own steel distribution business, and a picture of it would help also. Let me know.
Pat
Summit Steel
Oceanside, CA
In the refineries we use a simple copper-sulfate solution to verify removal of stainless steel overlay from Carbon steel base metal. Apply the copper-sulfate and if the metal turns copper/brown it will be carbon steel. If no reaction occurs then you have something else. Here are a few links for your reading pleasure.
Google it and you shouldnt have a problem finding a source for copper-sulfate. As others already stated if it shows some rusting after leaving water on it overnight you most likely have carbon steel. 309 SS filler metals are usually used to weld carbon-stainless base metals
Article: On-site methods for stainless steel grade product sorting
Spark
