Metal Tech sliders review
Pacific NW
Well, based on the advice of this forum I purchased sliders before I took the 80 out wheelin. All I can say is that I'm glad I did.
93-94 Version
Ordering:
I ordered direct from Metal Tech. Talked to a guy named Mark who was extremely pleasant and helpful. He was able to ship the sliders from Portland, OR to Tacoma, WA for about $90. I ordered them Tuesday morning and they showed up at my door by 5pm Wednesday. (results not typical)
Install:
- Front mud flaps do not fit. I looked at trimming them, but you would have to trim a whole lot and I'm not sure how well they would be mounted.
- On the DS, be sure not to crush the brake lines running along the frame. I had to remove 2 clips and bend the lines out slightly to get the U bolt between the frame and the lines.
- On the PS, the front bolts were a PITA. There is a hard line (rear heater I think) right up by where the plate wants to go. Be carefull not to jack the slider up and crush the line. (I dented mine a bit) Once you have the front in place, it was incredibly hard to get the bolts through the L bracket and threaded into the "cat guard" plate. I had jack up the inside while my buddy stood on the outer tube to get things to line up.
Function:
These things were great. I really don't have anything to compare them against, but I used them a bunch on my first trip out with 80.
- Managed to set my PS rail on a flat rock and get stuck. It was bearing enough weight to prevent me from getting traction. After getting pulled off the rock, there was barely a scratch.
- The kicked out rear came in handy. Really helped rotate the rear around a few stumps/roots.
- Place I went had huge holes (5ft deep, 10ft wide) dug into one trail. It was great knowing I wasn't going to rub my body panels when my front was in one hole and my rear in another.
Nice. Since they're local (and kick ass) I'm gonna keep them on my radar for when/if I decide to roll with sliders.
Takes a little elbow grease to get these on but the payoff is awsome!.
I have an LX and I delveloped a rattle from the heat shield of the exhaust. I removed it and problem solved.
looks like great sliders except for the silly u bolts, i dont know why every one uses thesee things they pinch the frame and take away structural rigidity there are easy ways around this
the MT sliders look to be the best set imo. however, i like a weld on vs the bolt on..but they have some cool features. the price on them was too rich for my broke ass, so i had to go with a set of stubbs.
now if only someone came up with a low profile slider for the stupid under frame exhaust piping...
oh yeah, that worked. those look super tight on your rig. nice.
Yes they do there job. it seems as well as the slee or hanna. I bought metal tech sliders because of availability and shipping. I don't think you would go wrong with any of these three choices.
I got mine a few months ago. The guys at the shop put them on for me. Intended to do a write up, but just too many other things going on.
These things look great and offer awesome protection. As far as the weld on verses bolt on, I had weld on sliders on my mini-truck and it worked fine, except for two problems. After all that welding, it turned out the cab flexed more than I realized and I had to live with the cab slamming down on the sliders for a long time. It wasn't a really big deal, but kind of annoying until I got used to it. I purchased and was about to install poly cab mounts when I discovered the weld on sliders were in the way.
I really like the bolt on design and it doesn't flex one bit. You'd never know it was bolt on.
It's a great design and worth every penny as far as I'm concerned. The features like cat protection and optional bolt on storage plate are pretty nifty too.
in picture #9 in your "first time muddy" are you hung up on your diff? Looks like both tires are off. This is where the jeep pulled you off huh?
Yeah. :doh: Slowly learning.
I made it up the pile fine, but when I was backing down my tire slid off the side of a rock and my axle sat right on the rock. Toyota 0, Jeep 1.
The time I got hung up on the slider we ended up pulling the rock out to the side with a winch. This time saved my the old LC.
I ended up towing a wrangler up a hill so it ended up Toyota 1, Jeep 1. The battle continues.
:clap:I echo all the positive review. I would have destroyed my rockers and side panels without them. Superior customer service. Excellent value. I installed by myself in an afternoon.
Strong thumbs up!
