- Thread starter
- #21
Someone correct me if I am wrong but don't the stock rubber bushings allow for not just flex of the joint during articulation but extension as well? Isn't that just the nature of the 5 link suspension setup that you need extension of the joint as well as flex to provide for max articulation?
The suspension on the 100 series is more like a modified 3 link with the uppers controlling axle wrap and the pan hard is what locates the axle from side to side. The axle doesn't extend so to speak but it does move in an arc through the suspension cycle.
Metal Tech -
Are the poly bushing holder the same size (dia.) as the OEM rubber bushing?
The poly bushings are 2.25" in diameter so they are a little bigger than stock and we use a 1" piece of DOM with a full 1/4" wall of support for the bolt to go through so there is no chance of inner sleeve becoming warped.
