I'm working on adaptersto put the Om617 into the Fj62 as well as new bellhousings for the Om603/606 to A440 as well. The Om 617 shouldn't have any problems moving an Fj around and still be reliable.
Brian
let me know when you get this done i'd be in line for one.
What engine 603 or 617? Will be starting the Om617 swap in 2weeks,still trying to get my foundry set up for casting new bellhousings for the 603 swaps. Been super swamped with orders and can hardly keep up and still work on the new products. Got my son and the couple I kidnapped from the store chained to work benches to help out.
Brian
Yeah... I'm really torn with that right now. I know my 3fe has a horrible time with the 50mph lock up limit of the a440f, but it would be super simple to just use my tranny (which I just put in less than a year ago) and I would like to use the full time 4x4 transfer case. I have been seriously kicking around an h42 swap.
As for the 700, I don't mind the cross member building... the speedo works from the t-case, there's only one wire for a 700r4, and drive shafts are a must on almost any transmission swap. I'm nervous about the low cruising rpms. It would be around 2100 at 65-70mph. I would love to get 2800 at cruising speeds.
And the biggest problem, 1500 bucks in adapters.
I have and old friend that has over twenty 300d, sd, and tds. No joke. I have almost unlimited supplies of engine parts and info. He thinks (and a few drives with a VERY loaded trailer confirms) a 617 will do fine in the 80. The Mercedes transmission is a 4-3-2-1 gear ratio. The final drive in a 300d is nearly identical to an 80 with lower gears and bigger tires. I also experience near 30mpg in a 3700 lb car. My cruiser as bone stock and weighs in at around 4600#. for example, If I would do a 700r4 with a 617a I lose aprox. 300lbs taking me to 4300. 600 lbs is the dif. There are a lot of guys running worn out 3fe 80s that weigh 6000lbs with all the armor they have on them. If I compare that, I'll have a MUCH better power to weight ratio with even a stock om617 than they do and I can run veggie oil and bio.
I was originally aiming for a 4bt, but this is so expensive, I can't justify it.
The 6.2 isn't available for me and I don't want a v8. If I did, I'd be vortec swapping this sucker, hands down. I want something easy to work on and lots of extra engine bay. I have done multiple engine swaps with small cars and big engines and I just don't want that with this one. When i was a kid I saw a bug with a twin cyl Onan diesel motor in it and these 2 old ladies were driving it. They said, "It's slow, but no one else has one". I loved that.
This motor moves around plenty of big mercedes suvs, so I can't believe I won't push the cuiser.
Anyway... I know I'm crazy... My wife tells me daily.
Have any of you tried mating a 617 to a 5-speed HJ or is that too heavy?
I'm getting more interested in the a440f to OM617 adapter. If you have a basic kit with the adapter plate and crank adapter for a fair price like your others listed on your site, I'm a buyer if i can get a few loose end figured out. Is that adapter one you are def. making?
