mE mAkEm FiRe Part 2
LandCruiserPhil
Peter Pan Syndrome
Supporting Vendor
Graham County, Arizona
Because of the 100's of positive responses and PM's I received from my 1st mE mAkEm FiRe thread I decided to do another. In case you missed it, link HERE
This time I will be using Magnesium & Ferrocerium to start the fire. Magnesium & Ferrocerium is a non-primitive fire starter you can buy in any outdoor store. To get started you scape filing from the Magnesium into a pile. Then you scape the Ferrocerium strip to get spark to ignite the Magnesium. In theory and a controlled environment normally its easy.
This time I created my own tinder bundle and did a beautiful job IMO from native plant sources read:green:flipoff2: Now the problems started I found it very difficult the form a pile of Magnesium in the heart of my tinder bundle(every time I touched the bundle all the mag fell to the bottom) and did I mention wind:mad:
After several failed attempts to start the Magnesium I believe I ended up starting my tinder with just a spark which is much more challenging. Bottom line I was able to get a coal started and with a little blowing I got ignition!
In part 3 we move to chemical fire starting:popcorn:
So I got this knife awhile ago, I got it cause it has the nifty little fire starter on it. I haven't used it yet, but your threads are giving me some motivation.
heaven for bid my truck gets stuck or broke down , im sure if i needed fire i could figure somthing out with a whole truck there:wrench::wrench::hillbilly:
Do it on the table, inside, on tissue and it will work every time with no problems.
O'Oooo electric fire maybe part 4
On a side note -If you drive an automobile long enough with a bad head gasket it will start on fire without any help.
will a spark plug light a soda can full of gas???????okay half full ?? if you do this we need vidio:eek:
If you had one of them nifty Coleman stoves, you wouldn't need to make fire.:rolleyes:
YoU tAlK eM lIkE mY nAmE TrAiLbUs1!!!:lol: Iz I wEtArDed?
NIce so do you feel the bow method is easier than?
For me with a good set up the bow is much faster (under 2 min) then any other primitive method I have tried. Most primitive fire starting methods are based on creating an ember and a friction bow is the easiest so far.
Understanding the friction bow is the secret. Like I said before I tried many times for many years before I mAkEm FiRe WiTh A bOw. It wasn't until I contacted a self-proclaimed expert from Kentucky:hillbilly: that help me understand the process.
HEck boy dis how u start em good fire LOL! Do like survivor man...move the camera grab a lighter..then move camera back hahahah!
Not Survivor Man, you must be thinking of Bear Grills.
