I was thinking of making a new manifold in the future, maybe something with runners. Not 100% sure how I'd seal the ports up, would probably need to get a plate made up with grooves machined for o-rings then weld the rest to that. But that won't work if I radius the ports on the head now. Maybe a bigger chamber/plenum would be enough of an improvement.
Any change to the manifold will mean getting longer fuel lines made as well.
But looking at the factory manifold it doesn't seem to bad, especially if the ports are smoothed out.
The butterfly is for shutting the motor down. But there's a fuel cut lever on the pump so I reckon I'll use the edic setup from the 3b to shut it down. That or just run a cable to the cab
Dougal is that 16% ignoring equations? So if the port is for example 30mm wide (that's a guess from memory without a ruler handy) then the radius would be 4.8mm across? I'm guessing your using radius to describe the port edge and not as part of a circle equation (half the circumference).
Not really able to improve the top and bottom of the ports much, the inside edge of the manifold is pretty close to the ports. Would doing the outside edges of the outer ports be beneficial?
Thanks for the input guys, there's some great info here.
