Hoping I could get some ideas on what my issue may be with my 03 LX master window switch.
Background - I have intermittent behavior. Previously the front driver would work (up and down by holding down or hold up but never AUTO). Only intermittently and with no repeatable behavior could I roll up/down the other 3 windows. All 3 windows can AUTO up/down on their individual switches. Power door lock does not seem to engage anything repeatable either, I've seen it lock and unlock and then it stops working. Window lock seems to consistently work. I can confirm that the other windows seem to respect when from the master switch I hit the window lock.
Troubleshooting attempts
1. Checked the original harness, and it looks like the PO may have had similar issues and tinkered to no success.
2. Checked specifically the area in the door jam at first. No broken cables.
3. Tried a replacement switch - NON oem master switch, did nothing but cause me troubles.
4. Replaced with an OEM switch on my stock wiring harness. Magically the master window seemed to consistently AUTO up and down. I was getting excited at this point.
5. Was recommended since I couldn't control the other windows, and since it looked like the PO may have tinkered, I should just replace the wiring harness. So I did. Here's when things start getting wonky and unrepeatable.
Testing on the new harness.
1. Now I can't seem to control anything, BUT on a few occasions I was able to all of a sudden AUTO up/down all of the other windows EXCEPT for the drivers front window. At one point I was also able to control the power window from the master switch. I saw it with my own eyes and did it repeatedly. Next day, nothing works again. So I flipped flopped between my old harness and new harness and nothing is repeatable.
2. I wiggled the harness connections and held and clicked on the switch to see if maybe it was loose wiring but nothing that I could repeat with any consistency.
More testing and troubleshooting
I read how many mentioned it could be the lock actuator, so I took it apart replaced it with a new one and tried again, nothing from the master switch.
I then tried lock/unlock from my remote and heard the drivers door lock with some real enthusiasm, so it sounds like the actuator is working and working strong. Then it stopped locking/unlocking.
Other testing.
1. Checked fuses, nothing blown.
2. Unplugged my battery for 15 minutes, nothing again.
I'm really at a loss. Any ideas on what else I can check or what may be the cause of this? The lights on the master switch for all of the windows are on, so there's power. The window lock control worked consistently on the new OEM switch replacement so it seems like SOMETHING is getting across to the other windows.
Other testing.
