First off, a disclaimer: I have not run the engine with the manifold, so I do not have first-hand knowledge Re thermal response.
That said, I read about an exhaust manifold treatment that seemed to make sense to me. For this process, a dry graphite spray, called "slip plate" is used. The article can be found here How to Restore an Exhaust Manifold
The basics are:
1) prep the manifold. Bead-blasting would have been nice, but I just have a grinder and a cup brush. I first applied naval jelly, then brushed the mani with a wire brush and washed it, then ran the cup brush, then cleaned it with brake cleaner.
2) Mask-off the gasket mating surfaces. I masked the studs as well, as I did not know how the graphite product would affect torque on the threads.
3) Spray several light coats of Slip Plate onto the manifold. This stuff dries fast, but will run if applied heavy.
4) The finished look is a dull, dark grey, UNTIL the manifold is wiped with a cloth. Then, the surface shines up a bit, and looks pretty good IMO.
From what I read, the graphite can tolerate high heat, and the product definitely got into the pores of the metal. I like the look, but only time (and driving) will tell how durable this stuff is.
Anyone else out there try this process before? @J Mack @scrapdaddy
Before
After prep
After spray and wipe-down
Got it at Napa for $9.99
The basics are:
Before
After prep
