For those using or having used a magnet mount antenna in the center of the roof. How did you route your cables ? Going to pick up the antenna for my CB later and have been searching on here for some ideas.
A couple folks made attachments that mount at the back gate, I have one myself, is there any reason why you prefer a less permanent mounting?
There is :
I had thought of doing an NMO style but am concerned about bending the sheet metal if the antenna gets whacked on something. The Wilson 1000 permanent mount looks cheap and i'm not convinced it would keep moisture out. Therefore my option is the mag mount. I do like the look of the hatch mounts but I don't like the idea of running a GB antenna from one end of the vehicle. Also I just got back from picking up the mag mount.![]()
All right, so I couldn't stand the thought of running a wire down the side of my rig, and I don't really like the look of the mag mount up there. Just called and set up an appointment to get an NMO mount put in the center of the roof. For $60 it will be worth it to just have someone else do the install. I think this is going to make for a much cleaner and versatile option in the long run.
