- Joined
- Sep 4, 2020
- Threads
- 122
- Messages
- 1,615
- Location
- Brunei Darussalam
- Website
- eurasiaoverland.com
I have a flywheel for my (diesel) engine which needs machining. From factory it has a 0.60 mm step between the outer part of the flywheel which the pressure plate bolts to, and the inner area which makes contact with the clutch disc.
Should I just have the inner contact surface of the flywheel machined to remove surface imperfections? Or should the outer section have a similar amount removed to maintain the step height?
Thanks
Thanks
