This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
rock scientist..
Staff member
s-Moderator
Moderator
So since there are no MAJOR mods to be done to the 40 this winter I decided to actually do something about how UGLY she is..
Got drunk last night while watching OCC Picked up a couple of ideas...
Also, some nut wanted the gas filler in the tub. I have hated the @&@&@&@&ing thing since I did the body swap in 89 (not a misprint.. 1989)
"Hallucinations are bad enough. But after awhile you learn to cope with things like seeing your dead grandmother crawling up your leg with a knife in her teeth. Most acid fanciers can handle this sort of thing. But nobody can handle that other trip-the possibility that any freak with $1.98 can walk into the Circus-Circus and suddenly appear in the sky over downtown Las Vegas twelve times the size of God, howling anything that comes into his head. No, this is not a good town for psychedelic drugs."
rock scientist..
Staff member
s-Moderator
Moderator
I love BBQ lids....
All sorts of available options when you need a nice constant radius..
Got the front and the rear of the rear fenders mocked up.
I love white paper. It almost looks like I have already done work to the beastie..
rock scientist..
Staff member
s-Moderator
Moderator
@nd part of getting this crap done is making it ride nicer in the rear. From some of the above pics you can see the rear shocks.. They are at a HIDEOUS angle that is ALMOST useless. And bottoms out whenever I hit a bump. IT sucked. F'n grogan and Rascall were airing (I use that term loosely) it out on the dunes at the TB jambo last year. I knew that if I had even thoguht about it I would not ahve made the trail runs the next day.. So I had to run tha camera with my tail between my legs..
Picked up a set of Pig's BBCS 15" travel shocks for coils.. I really like the integrated bumpstops. WEll, mostly cause I do nto have ANY bumpstops in the rear
Mocked them up to see how everything fits..
rock scientist..
Staff member
s-Moderator
Moderator
BTW, the rock sliders are made by 2BadFJ's
Don't tell me that a body mounted slider can't hold the weight of a piggish 40...
The highlift is one of the big 60" ones..
The 60 on the right is on 35's for refrence...
I can't wait to jump the beastie again..
Sweet Mace.Bump stops?Wear a mouthguard and a kidney belt!
Will it finally get paint?
dude . Thats a killer idea.
Now body panel replacement is a breeze and you can change colors easily.
I would suggest the colored elec. tape tho.
John on the hawgs
rock scientist..
Staff member
s-Moderator
Moderator
Yes it will finally get paint
Hey what kind of springs are you running in rear??
They look like coils to me..
Good job Mace... I look forward to seeing it in metal.. I suck at that kinda stuff, so I always just cut... As you can tell, my junk needed alot of help in the body tub area..
rock scientist..
Staff member
s-Moderator
Moderator
interesting spring hangers on the rear x-member
look pretty
jason!!!
rock scientist..
Staff member
s-Moderator
Moderator
the leaf spring hangers are where I had my suspension at 104" and leaf springs.
They worked very well that way.
I suppose I should cut them off...
hang some" truck nuts" off them !!
Sorry I meant to say coils.....my bad...what kind of springs where you running when you did have them on there?
rock scientist..
Staff member
s-Moderator
Moderator
Rear leaves were FJ55 springs inboarded...
Suppose so if you want to make it "prettier"
It is oogly
rock scientist..
Staff member
s-Moderator
Moderator
LAME said:
It is oogly
Go get a job
Too busy for that @&@&@&@&
