Builds Lynchburg Lemonade, matzell's STW (1 Viewer)
Well, at beer thirty I am taking a break to see what is next. I feel that I have been rolling the last few weeks. All the work on Lynchburg and installing and ARB in a friends 40 and welding up his labs bumper. Plus the surprise water pump job. Had to put a rear pinion seal in the GMC as well.
It will all be worth it in just over a week sitting at the top of Imogene staring off into the distance and snow covered peaks.
Let the haters hate but, I will always have heat and a/c in my home shop!😊 It is in the high 90's and high humidity today. That would suck. I would do it, but this is much better.
Well my elation of having the water pump out the way was short lived. Found a small drip this am. Snugged up a couple of nuts. Test drove for 30 mins and found one drip. Tightened the nuts a little more. Cleaned and let run. It would take about 20 min then drip would form.
Not wanting troubles on the road, 2000 miles each way. I pulled it all back down. Found the paper gasket from GM was leaking. Should have put rtv on it.... put rtv on old metal gasket and reinstalled. Shaved it down to under 2 hrs. Cool. Went to fill it with Dexcool after painfully straining 4 gals and found the leak at the bypass pipe from water pump to t stat. I mean like really leaking. O ring tore going back in
Oh crap! I went inside and searched google. Found Dorman makes an oring kit. Called around and one of my suppliers had one at the Richmond hub and they were open!
Off I went in the 80 to pick up two o rings, 3 more galloms of Dexcool, not knowing how much I lost, 3 gals of distilled water and some stay dry. Got it all back together and checking for leaks now. Seems good.
I leave in 5 days for SAS. Not sure I want any more surprises! And it is pouring down rain!
Hey thats my coozie! Ha not really but I do use it quite often 🤣
All loaded up to head to SAS 9 this weekend. I did not realize how much Lynchburg had grown till it was next to one that was the same size as mine used to be. He even has my old tires.
