Think it was the hinges, the shock ends, and the third bar going into the panel on the right side. Just a little white lithium grease sprayed while moving the hatch.
I just replaced mine last week. My trunk was opening but would not open all the way. Due to the fact that it has an electrical assist, I ended up ordering OEM struts through parts.lexus.com. If you look at different dealerships on the website, you can typically find one or two that are much cheaper than the others. I got the best deal through Jim Hudson Lexus of Augusta. However, it will be cheaper to do a set on Amazon.Since we are on the topic, has anyone replaced the struts on either side of the rear tailgate? Do they have to be Lexus branded or anything special? Or can you get away with aftermarket normal tailgate struts? Thanks again.
Bringing this up so as not to start a new related one.
Mine is no longer closing. Opens perfectly (replaced struts last year). The mechanism starts, then seems to meet resistance, then beeps and gives up. Could it be the motor? Any suggestions? 160k miles on it.
as far as the pneumatic tubes, i strongly advise to ONLY use OEM.
got some aftermarket tubes for a RX350 liftgate from auto zone. looked legit. but a few months later one disengaged from the ball it was mounted on when i was opening the liftgate. luckily it did not punch out my eye or smash the liftgate window, but there was a lot of force in it as it jumped on its own.
go with OEM only, even if it does cost a little bit more.
Where they not provided with the clip/pin/spring to prevent that? Or was the clip missing? Mine came with clips at both ends and there is no way the ball can come out of that socket unless the clip is removed.one disengaged from the ball it was mounted on when i was opening the liftgate
yes it had the clamshell clips. but it twisted itself in a way that the clip did not hold it. slight differences in how it was manufactured, vs OEM part, meant it did not stay on the ball.Where they not provided with the clip/pin/spring to prevent that? Or was the clip missing? Mine came with clips at both ends and there is no way the ball can come out of that socket unless the clip is removed.
reading the .pdf above, i should add that i did NOT replace the two balls, just popped on the replacement strut on top of the existing (worn) balls.yes it had the clamshell clips. but it twisted itself in a way that the clip did not hold it. slight differences in how it was manufactured, vs OEM part, meant it did not stay on the ball.
So I had these installed aI got these struts:
18.54 Inch Lift Supports Depot PM3296L-R Lift Support | PM3296L-R-W
Our Lift Supports Depot PM3296L-R fits a wide variety of vehicles and includes a 1 Year warranty! $6.99 Shipping on orders $29.00 and over.www.liftsupportsdepot.com
Haven't installed them yet but will report back on fit and finish.
So I installed these over 3 years ago and I am happy to report they have been flawless on our LX.I got these struts:
Hey guys dont mean to necropost here (is that the right term?) Anyway, was wondering if anyone knows what the little button beside the main tailgate button is for? I press mine and it does nothing. For a second I thought maybe the glass opened but thats not it. My power function also doesnt work to open only close but after reading this thread I will check the main button in the front. Mine is a 2013 FYI
Yes! Thanks lol. After about half an hour of dicking around I figured out thats what it is.Meaning under the tailgate when it’s closed? Next to the main button to open it?
If so the little button locks the car if your key fob is with you while you press it.
