Lx570 coolant change
Just getting some opinions. 2010 lx570 currently receiving used engine replacement with 45k on it (my truck has 235k and a bad head gasket pass side number 4 cylinder) see my other post about that. Once done I plan to replace the coolant every 30k from now on. Are you guys just draining the radiator or are you draining the block too?
if you’re doing it every 30k, just drain the radiator and refill. Solution to pollution and all that.
Will you get the latest radiator installed as part of the engine swap, to prevent the know crack issue in the pre 2018 vehicles?
