arnott1t
Hey Folks. 2009 LX570 with 230,000 miles or so on it. Bought it with 80,000 or so miles and have loved this ride. I've had some troubles with the AHC system... A little history:
Fluid change at 90,000 miles - not sure if it was the first or not:
Fluid change and globes at 190,000 miles or so. Late I know but life was busy the last little bit
Pump failed then.... bad fluid into the pump.... the typical --> wish I would have read that thread before the job thing.
New pump installed
Ever since the system has been a bit off... would have a bad lean to rear left side often.... you'd drive a bit and then it would straighten out. Sometime it would throw a check VSC code sometimes not. Didn't always do it but did it often enough. Fluid level is up. Can be fuccy going up and down. just isn't working as well is it did at lower miles.
Lately much worse. Falls to low and get stuck, won't come back up on its own.
I can use a fancy scan tool to log into the AHC module and scan codes. Getting a C1763 Oil pressure for pump motor abnormal. Clear the code but it comes back after a while.
The tool also lets me activate the system to test. So manually I raise and lower each corner or front and back. All my height sensors seem to respond and pump seems to build pressure fine.
Any thoughts on what to do? I'm this close.... to replaces with springs and shovcks and getting out of AHC.
Also of note. Rusty under carriage truck.... Just the nature of things up here in the north,
What should I do and or check? The VSC system throwing codes, could that be my problem?
New pump installed
