LX570 AHC fluid change issue
UPDATE...
First off hats off to this group to get back to me with a bunch of options/theories so quickly. Great community!
Summary - I caved.... I am going to change out the height control pump for a new one at the Lexus dealer... So I am taking this one on the chin.
1) At first I started to drive the car home, with the long shot hope to try to wait for the pump to slowly do its thing and refill the globes. You guys gave me hope that patience at home may refill the system. However, with the car on the bump stops, the car was borderline undrivable. Worse than driving in normal L mode. Furthermore, any 90 degree turn created a ton of tire rub against the body. I didn't want to risk any further damage for my 30 mile drive home.
2) The master tech took the extra steps to get back on the car to troubleshoot, opening all the values to try to force fluid into the globes; activating the pump with the fill tube open. He came out numerous times to keep me posted and even walked me back to the car multiple times. I really think he gave it his all, and I am just doubtful I would do any better at home. If I made it home, I would likely be left with the only option to floor jack the car up and bleed the system further. But I assessed my odds at an extreme long shot to get anything re-pressurized.
3) The parts department wouldn't budge on the MSRP price $3300 - yikes. So the tech and service advisory were super cool for me to order from Toyota for $1200 cheaper.
4) Labor will be 5 hours. 3 hours to remove and re-install the pump. 1.5 to 2 to purge and refill the system.
5) The Mrs is getting impatient with me and just wants her truck back...
So I'm leaving the car there for a least a week while we wait for the part and the long weekend to pass. At least I have a nice "loaner" car in a brand new RX500h.
Morale of the story...
Not sure if I'll ever do a bleed again with the 5th accumulator. I'll just stick to bleeding the globes.
I requested to get the old part back, as I want to inspect and test to see if there is fluid residue clogging the internal strainers or if the motor truly burnt out and not pumping. I realized that I misspoke earlier in the thread. While I bought 2 new cans of 2.5qt fluid, I started with a left over quart of AHC fluid (unopened) from my last fluid exchange in 2021.. Could I have a bad batch? No idea - but I didn't have any issues with the other 4 quarts I used for the last exchange in 2021.. I still have the bottle which presumable has the lot number on it.
At this point, I still can't figure out what I did wrong to end at this point. The last time couple times I did this AHC change on my truck(s), I never bothered with the accumulator, just the globes. According to the master tech, they only do the globes and never bother with the 5th accumulator as it isn't mentioned in the 200 series FSM procedures. That will be my costly lesson. Hate to go straight to the parts cannon, but fingers crossed.
At least you are getting it fixed!
I have seen folks on here bleed the 5th accumulator. IMO a lot of the CHECK AHC errors come from draining too much fluid from the globes or the accumulators. Slow and steady is the best practice.
I changed globes for 4 trucks (5 including myself) and I only encountered the check AHC error on my own due to me bleeding the globes till empty. Solution was to manually activate each valve and let the globes refill.
If you started with the plastic quart, I bet it was contaminated - one option might be to yank and bench bleed the pump?
I concur that the plastic container was probably the culprit. Be interesting to see what’s in the reservoir.
Container complete with the origin and date sticker still on my garage floor after I got home. Anyone know how I would know which batch was recalled or had a stop sale on? Will call and let the master tech know to make an official observation on the pump when he pulls it out. Any specific area he should pay attention to?
I’m not sure if anyone has made a correlation on the batches of fluid. The bad fluid had a goopy clear solid floating in the fluid.
Contact the dealer and ask if they can do a goodwill claim with Lexus
After reading a few recent threads on the 100 series forum this evening, I am too very convinced that contaminated fluid is the culprit here. Given that I have the bottle with the dealership markings on it, and I also have Lexus changing out the pump in a few days, I may have a better chance at a goodwill claim.
It seems most of the other folks that have pulled, dissected and cleaned the pump have done so on the 100 series, where it is much more accessible. Anyone have experience with the 200 series AHC pump? I need some guidance on where to look for my technician, when he pulls the pump from the car. I am doubtful he will pull it apart, but if the contaminants can be located in plain view and he can document it vs me, I probably will strengthen my case for a goodwill claim.
Thanks again.
So I was able to remove the pump out of the car today. I was able to disassemble it quite easily. While the tank did seem to have quite a bit fluid that may have had containments, I wasn’t able to see any goop blocking the 3 the brass ring “filters” on the pump head. I cleaned them anyway. Pump gear internals looked great.
I tested the pump after a thorough cleaning with water. Attaching a video. Not sure if I have a weak pump or if the pumping efficiency I recorded is normal.
I probably will have them reinstall the cleaned assembly tomorrow.
Any thoughts on the video?
