TLX100, I plan on using some trim packers if I can't get back into spec with the non-ahc coils. Thx for reaffirmation.
Wilsil, Coils for sale?
Joel and Super90, I understand that most people go with OME, this is not a smart thing to do IMO. I think that losing the AHC for someone who does not primarily off road is a bad thing. I have 160k on the lx and have not had any issue with it. Change suspension fluid frequently never had any serious issues with any system in the car, and have used a techstream to repair anything myself for very very cheap. Aside from the actual compressor for the AHC going out, the system itself can be repaired three times over before an OME system would breakeven.. and even then I would lose my control over load cap and ride.
Super90, I have a minivci and a techstream, hence the reading. Also, my vehicle has never dropped into low. I have loaded over 700lbs into the the vehicle, including 2 big men, and a ton of boarding gear, since the changes(before my techstream reading) and the vehicle maintained proper height throughout. IMHO it is flawed logic to assume that a vehicle cannot be maintained with mixed components, as there are several instances where mixing components leads to a far superior ride.
Was a simple question. All I want to know is what non-ahc coils I can use?
I recently added larger tires to the lx and had to AHC raise them to get the tires to fit and look proper on the vehicle, this coupled with my last techstream check being almost 8 months ago, has probably lead to me being so far out of spec. In fact, I just checked again today and it seems that when I go from L to N on the vehicle the pressure in the rear reads 7.7, not too far off from spec. I have not been driving the lx because of this, and am hoping to get back to spec before I do any more traveling. The NONAHC Coils will work better since I have performed the ahc lift. Else, I can get the ahc OEM coils and add a 20-30mm spacer, however the fewer the pieces I have to use to compensate the fewer points of failure I can have.
There is a lot of opinion and speculation above. I simply wanted to know what coil to use. I am guessing I can just get a lc100 coil from a similar year as my lx and it will be fine?
Are the lc rear coils much cheaper? I will have a look myself in a sec.
Thanks in advance guys. Sorry that I didn't post more information in my original post.
