Jim_Chow
V8_Fan
- Thread starter
- #21
NMuzj100 said:OK, where can I get "Landcruiser Magazine" ?
I got mine at a bookstore in Sapporo station.
Jim_Chow said:I took a look at the 100 series maintenance article in the Jan 05 issue of Landcruiser magazine, and it says just to check the level and if it's low, something is leaking and you have the dealer fix it. It says to use Toyota-brand hydraulic shock oil for it, but doesn't say what the substitute is. And who knows how to flush the thing?
As an aside, I was looking at the fluid capacities of the LC100....man, the 1HD-FTE uses 3 gallons of oil for each change! The H151 5spd manual tranny uses less than 3 qts of fluid, while the auto tranny uses like 4 gallons of ATF! Talk about cost differences if you're using synthetic!
dclee said:I don't know much about the Lexus system, but it sounds like it may be similar to the Mercedes system that has been around since the 1970s. Basically, you have a hydraulic pump that feeds oil from a reservoir to the dampers. There is usually a mechanical sensor (in Mercedes case mounted to the rear sway bar) that can sense when the axle is being compressed. When it does so, it opens a valve and pumps more hydaulic fluid into the dampers to raise the chassis back off the axle. The nitrogen accumulators are plumbed downstream, and have a membrane that separates the fluid-filled portion of the sphere from the nitrogen-filled half. The nitrogen side is what provides the "give" against the fluid in the dampers and allows the system to actually damp the springs. If the membrane breaks (most common failure) then the entire accumulator sphere fills with fluid, and no longer can dampen the spring. The ride will become very hard at this point.
The downside is the complexity and expense of repairs. Can't simply throw in a new shock. The upside is complete rebuildability (even the dampers can be rebuilt - usually it's just O-rings that go out on those).
But, if you do decide to ditch the system, look at all the components and make sure you account for them. For example, the hydraulic fluid pump on the Mercedes is run off one of the camshafts. If you remove it, you need a block-off plate for the head. But you can probably drop about 100 pounds if you rip it all out and replace with a standard LC suspension.
Anyway, enough rambling for tonight...
hoser said:Good information! Ben, just wanted to clear up something. You refer to "Accumulators" but do you really mean "Actuators" (Damping Force Actuator). See Diagram. Just don't want anybody to special order the wrong part.
I have read good things about Keith Bowers at B&B Suspensions. He rebuilds the actuators at a very reasonable price ($175/ea). You can reach him at: kebowers47@hotmail.com
Hi,Can any LX470 owners out there comment on the longevity of the hydraulic lifting shocks/accumulators and their maintenance/replacement? Do these have the typical lifespan of shocks (30K or 60K mi), or are they designed to last 20 yrs and 300K miles? Figure that the first 5 yrs of the typical LX mall cruiser is always in the "low" position and gets nil use.
BTW, anyone know the price of a t-belt and water pump replacement at 90K mi for a LX vs a LC, assuming a Toyota dealer won't work on the LX so you have to take it to the lexus dealer?
You only need to replace the shocks when they leak. I have replaced two shocks since new and now am at 620,000km. Replaced the 4 accumulators at about 500,000km when it was evident the nitrogen had leaked internally. The AHC system provides a marvellous ride and I do not understand the fervour some folk have about replacing the system with inferior standard shocks.Reviving as I'm currently looking at my 2003 LX with 183k on it, and will be replacing the front shocks. I did the acuumulators (globes) myself about 200 miles ago along with a full system bleed/flush. I got all of them for $600 shipped from Japan. You can also get the shocks themselves for $205. At 22 years old and the original shocks, not knowing the previous histroy of how hard it was driven, I'm going to do them. Have some bounce/vibration especially out of the front passenger. Heard a lot of "shocks will last forever, it's the globes you need to replace" and while I don't disagree the globes may go out before the shocks, the truck has Northeast origins and there's a lot of corrosion. Will post back after replacing and update on ride quality.
