- stock Cummins mechanical fan works great. You might need to trim and block off the little nipply on the top left side of the radiator to clear the fan
- Power steering is easy. A few readily available adapters for the steerin box and then have a hydraulic shop make you a hose.
- Toyota/Lexus tach requires a 3 signal pickup to work correctly. The 12V motors have a harmonic balancer with 2 pickups. To overcome this you can get a 24V cummins harmonic balancer which has 0 pickups. You then machine 3 equally spaced notches into the 24v balancer. This is a cleaner solution than using a conversion box in my opinion.
- Clutch Hydraulics: Get a toyota 80 series clutch master cylinder and an NV3500 slave cylinder and then run custon line between the two. on my setup i got both an NV4500 and an NV3500 slave cylinder and used the push rod from the NV4500 with the body of the NV3500 slave to make it all work correctly. You may need to weld in a small spacer on the master cylinder push rod to get enough throw. Pics and details can be found in my thread.
- Make sure you run two big starting batteries wired in paralell. These motors need lots of juice to start.
- Wire up your grid heater with a monetary switch on a seperate relay.
