You bring up another good point: the effect heavy load has on the system.
So how long have you had your LX and how many miles of trail has it seen?
Is there any data out there on the suspension travel of AHC vs non? I know I picked up a considerable amount with the long Radflos over stock.
I've been on trails for sure but not a huge amount relative to the asphalt duty it's seen. I've have been on a rather varied mix and not once have I found the AHC system to be what holds the car back. On the contrary, I find it to excel at just about everything I've tossed at it.
Andrew are you towing a CT every now and then?
My system drops down to low when we go away for a trip with the Kimberley Kamper in tow.
That's even before will add a dual spare wheel carrier and a bigger fuel tank.
Don't be alarmed at the system 'dropping to low.' It's not necessarily in a low position (kneeling mode), just that it's telling you the suspension is riding at a lower position relative to 'N'. The readout serves two purposes: 1) mode selection and 2) actual position.
The system is constant height within a specific load capacity. Beyond that, it is best effort. Just like you would expect a normal suspension vehicle to ride lower with greater load, the AHC system will do just that outside of the normal load capacity. Nothing is wrong, it's just telling you where things are at.
I likewise have run into this towing this setup. Note that the Porsche is rear motored, so there's probably 1k+ of tongue weight here with another couple hundred pounds of wheels in the trunk. And AHC performed flawlessly even in 'L' even though it obviously is not kneeling mode low. I would hate to have done this dragging butt without AHC.
