I think I would be asking the Lexus dealer that question. I have never heard of any street legal vehicle that goes through front brakes at 15k. I assume you don't drive with 1 foot on the brake?Does anyone have a guess as to why an LX would need new Front brakes at 15k while the rears still measure 10mm?? Seems really odd...
Thanks!
Yikes .... I never heard of that but my assumption is that a Lexus with 15k on it shouldn't have anything crazy like that going on with it. But I realize no mfr is perfect and although I am a bit surprised by the more common issues in the 200 series (radiator hairline crack blow outs, water pumps, etc) I know their frequency is much lower than competing vehicles like Land Rovers.While fairly unlikely, I will still mention something similar that happened to me. I say unlikely as my finding was on an older vehicle with a bunch of miles on it.
Years back a rubber section of one front brake hose had an internal failure. The failure was such that when brakes were applied they seemed to work OK. But when the brakes were released a "flap" of the internal section of hose prevented all the pressure from being released.
This failure mode meant no brake light was on. But the front brakes had the equivalent of someone "riding the brakes" while essentially no effect on the rear.
It happened over time so I, being super observant (not), never saw any indication. It was only when I went to replace the lines with some stainless hoses that I found the condition. And that was when the hose on the caliper end was loosened and fluid squirted out rather than just the normal sort of line draining. And of course I had to source new front pads.
never thought of thatAre you taking your LX to the track?
Excellent point and why I'm looking for a LX.For decades toyotas have been very reliable overall, but usually had one or two failure points with each model that seem like terrible design flaws, but in reality are easy to keep track of and address as they come up. Contrast this to other brands that could have any number of system failures.. and you have no idea what is going to come next.
I don't, but potentially the prior owner of this LX did. But I still don't get how the fronts can need to be replaced with the rears in such relatively good shape. My thought was maybe the brake force distribution logic ( if that makes any sense and even exists in a control module) was/is routinely applying too much to the fronts and not enough to the rears. I agree though that the Lexus dealer is probably best able to answer that question.
Did you find/confirm the brake wear yourself? I ask because if a dealer told you it needed front brakes you might want to double check. What year and how many miles?Does anyone have a guess as to why an LX would need new Front brakes at 15k while the rears still measure 10mm?? Seems really odd...
Thanks!
The new cruise control system uses the brakes to slow you down
