Interesting, thanks for sharing that. Hmm.. although I’m not worried about 110, maybe back off a bit? What are you doing?
I think the answer to this question is -I've always been curious about the lower, 76 ft-lb, value on the alloys. What would be the downside of higher torque value? Since that type of nut does not apply any wedging forces and is purely compressive, why need for the lower value? Could it be that 76 ft-lb is the reasonable lower limit but higher values would also work? If not, what would be the negative effect of a higher torque value? The studs are the same, so that's not a limiting factor. Could the threads in the shank-style lug nuts be that much weaker (seems unlikely?)
Well - yeah - Hmm... here too.Interesting, thanks for sharing that. Hmm.. although I’m not worried about 110, maybe back off a bit? What are you doing?
Also, the shank style wheels are HUB centric so the "weight bearing" of the wheel is on the center of the wheel to hub instead of on the actual lugs. The lugs only clamp the wheel to the surface to resist side forces.Well - yeah - Hmm... here too.
Not crystal clear to me yet either, so my tentative policy for now, reading between the lines - the Gorilla 75-85 guideline is so close to agreement with the Toyota washered shank 76 number...so I'm going with 80, middle of their spec and (don't tell the authorities) I've used that easy to remember number on the Landcruiser forever...5% above spec? pfft - well within instrument error plus component strength margin - Mr T (over)designed it to deal with the real world.
They always come off without any drama, and never loosen or show any bad signs.
But, as I delved into above - am dubious of the idea that - cones is cones is cones - suspect the 109 number is leftover from designs of another era.
But now - this is a new untested deal - Should do a few re-torque checks and look for signs until I gain confidence...
And - been meaning to call Gorilla and ask...
Not all is so black & white however....the shank style wheels are HUB centric...
The cone (acorn style) are LUG-centric...
