ncoleman said:I've been told LSD is the best...
ncoleman said:Looking for reliable info for a 4/80 fj40. What are my options for locking the diff(s)? I've been told an LSD is the best I'll get on a 4/80. What are the pros and cons of these different setups?
Poser said:Locking differentials are not the same as limited slip units. A limited slip unit does just that, it limits the slip; it does not lock the two axle shafts together and split the power available to the axle shafts predictably and equally per side like a true locking differential does.
it most certianly does.. but why go halfway???Lupdog said:Excuse my ignorance. I know a difflock is better but does a LSD actually improve offroad performance? Does it improve traction or give more power to the wheels at all?
ncoleman said:Can anyone direct me to a site or refer me to a source that can verify the following.
Can a April 1980 Fj40 run selectable ARB??
To those who replied I am much obliged.![]()
Mace said:Figure $1200 to $1400 for one ARB with install..
I disagree that ARB's are the premier option.. They are a good option for someone that does not rely on traction. I prefer the autolockers or a spool myself..
Unless a fuse blows, or you run out of Co2, or a seal goes bad or a hose leaks (or gets ripped off)Cruiserdrew said:Mace-I have to disagree. I have been running ARBs on my FJ40 for 5 years and my 80 series for 4 years. They ARE the premier option. Open if you want and locked when you need. What isn't to like. They are stronger than a stock diff and transparent when not locked. They are the best of both worlds. When locked, there is no difference between a locked ARB and a spool, plus, you can unlock the thing for on road handling or better turning in high traction spots. I leave the ARBs off 98% of the time, but the other 2% they make all the difference.
As you can tell, I think ARBs are great. A good install is CRITICAL. There are no downsides to an ARB except the expense. If you want cheap-weld the diff. Otherwise, the ARBs are a good investment.
Mace said:Personaly, I would do a factory cable locker over a ARB any day of the week..
Soul_Man said:Can't you only put the cable locker in a full floating axle? That was what I wanted also, but wound up getting ARB's rather thatn getting a whole new axle.
Also, regarding LSD's, I've always been under the impression that they are good choices for the front axle since they won't bind up the steering as much as a locker. Steerability is another good point in favor of using a selectable device if you go with a full locker, I think.
