I'm looking for a 5.3 or 6.0 powered 40…or even a fuel injected SBC 350 will do….just a fuel injected V8 40 series that I can't see through the holes in the body. I'm planing on a 1 ton swap, so axles aren't important….any any location will do. The plan is to make a driver,1 ton V8 cruiser..in the 100-109 WB range…so the better the candidate, the more inclined I'll be to purchase it. Or if you know of a 1 ton swapped ring with a 1F or 2F that could work as well for a motor swap. Something I could drive home would be preferred…..Range of 10k-30k depending on what you got!
