LRA aux tank fill-up observations
Next time you use and pump until it normally shuts off. At this point you already know from your last fill up how many gallons of usable fuel you have "at this point".
Then when you get home, if you have time the the vehicle power on but don't start the vehicle. (i.e. press the ignition switch 2 times).
Go open up the fuel filler cap. Go turn on the pump and watch it pump the fuel through the filler hole. You will hear how loud the pump is pumping fuel.
If the pump turns off again while still pumping fuel press it a 2nd time (or even 3rd) . and watch and listen to see at what point in time does it stop pumping fuel. Then turn it off.
Then you will know how much usable fuel you have and how many extra times to press the button if desired..
FYI: When the "red light" for the aux fuel transfer controller turns on it is programmed for how many more minutes to pumps fuel. This is adjustable.
how do you adjust the programing of the controller?
Ah, very cool info here. I’ll run this test and see what’s in there.
I believe my pump is programmed for 3 min once the red light comes on.
I have had my LRA 24.5 for about two years now. I typically fill both tanks at Costco.
After driving around for days/weeks, I refill the main OEM tank from the aux until the red light comes on the LRA gauge and LRA (upgraded) pump stops.
On the next Costco fuel up on the LRA, station pump typically cuts off on avg. 20.5 gallons.
Do I have ~ 4 gallons in the aux tank just hanging out?
Curious on your experience.
1st…
I VERY routinrly pump 24+ into my LRA when filling up…so it definitely is capable of sending all 24 to the main.
Couple possible expkanations (theories that are harder to prove)…
After having mine for about twice as long, I’ve become convinced that a full main tank can (perhaps) end up allowing some fuel to find its way back to the empty aux over some time and sloshing…because after emptying the aux, it will sometimes emerge as *one green light* on my small aux tank indicator later, even though I know I’ve emptied it…and sure enough, and all green level indicators were extinguished .
Can’t prove that…so note sure…
2nd thought is— Its RARE that I can dump all 24 from my aux to the main in one go, since its rare that I have a full 24g of space available in the main.
When the main reads E, there are about 4+ gallons in the main…meaning you only have room for 22.
What I am CERTAIN OF, though, it that my 24g aux tanks is very much capable of emptying itself enough to pump 24+ into on many occasions.
Your main though… While you can certainly empty it…You don’t want to do that. So unless you’re on a long highway trip where you can make sure your aux empties, there’s a good chance if won’t have room to fully do so day to day.
I've had my 12.5gal LRA for about a month now. I'd say it's a little tricky to know exactly how much is left in the aux tank. I find the light indicator to be very delayed and inaccurate. I have all stock hardware as far as fittings and pumps go. My usage at this point has been to transfer the entire aux tank when I'm at 1/4 tank on my main. The entire transfer will fill the main to about 3/4 tank. Since the light indicator is delayed I usually just do it until the pump starts making that loud noise which is usually when the aux is empty and just sucking air. I didn't upgrade the pump since my tank is only 12.5gal and it doesn't take too long. I suppose it's probably better than I have the stock noisy pump since that lets me know when the aux is empty rather than relying on the light indicator. So far its been a great addition and the 12.5gal is probably easier to use than the 24 or 40 since I always just transfer the entire aux tank each time.
That makes sense. I don’t plan on getting every last drop out but it would be nice to know where those extra gallons are at and if they are accessible if need be.
A few gallons out of 64 don’t sound like much but those 25-45 miles could make a difference in an emergency. Also, I don’t make a habit of running either tank completely empty, I don’t think I’ve ever seen my low gas light come on for the main tank.
This ^^ same thoughts.
I think there is space for expansion that is not normally available for fuel, but is calculated into the volume of the tank.
I have a 40 and have never been able to add 40 gallons of fuel to it. 36 or 37 has been my max. Unfortunately, the installer put "some" gas in it to test it out so I never was able to try and fill the bone-dry LRA to get a baseline. I think @nuclearbeef is on to the true reason here. Most gas stations have level fueling pads, but few vehicles are also 100% level. That's assuming level is the optimal position for max fuel fill with an LRA. I wonder too how much of the capacity versus actual fuel is driven by the auto-shut off on most fueling nozzles and a modified filler neck? Further we don't really know if a) the tank was truly empty/dry when we go to fill it and b) if when the pump shuts off if the tank is truly full. Getting confirmation of either would require a good bit of work and knowing the answer wouldn't change anything about how I use it. Maybe someone from LRA can chime in with the definitive answer.
In the end, what I know is that I have a nice reservoir of extra fuel in the car for when I need it. I can always imagine a scenario where an extra 2-4 gallons would be nice to extract (if it's really there at all), but in practice I am never that low.
Its just some effort if you really want to know what's left in the aux tank (drain plug). How important that is to anyone is really up to the anyone. No right or wrong here. My brain is wired in a way that I have to know, so I will find out. I accept and embrace my position on the "spectrum".
I'll look forward to hearing your results.
This time I let the pump run to auto shutoff and then hit it again which turns the pump on again for two minutes the auto shuts off again.
Pretty good.
It looks like I have 2 gal left after first auto shutoff. My need to know is satisfied.
Just got 24.1 gallons in after running the pump after auto shutoff…
Y’all running that gas pump WFO or on the slow speed? I go slow thinking it will prevent sloshing and help it fill more.
Also, I was assuming we were talking about the LRA pump running after it auto shut off 🤦‍♂️
I click the gas station pump down to slow when I think is getting close to full.
Yes, we’re talking about running the LRA pump again after the first auto shutoff.
I had to reseal my LRA tank outlet this past weekend due to a seeping gas leak. Before I did the work, I pumped it out with the included facet pump, and when I removed the tank drain and outlet, not a drop came out. So at least on my 12.5 gal, the included pump is capable of pumping it dry.
WFO at my Costco. However, I have noticed some stations are more sensitive than others.
Yes, seems like filling the LRA after the first auto shutoff leaves 5 gallons in the tanks - same as the Toyota low fuel light. When Running it again after it shut off, the pump was louder at times, but I could tell it was grabbing more fuel.
I’ll go WFO on my next fill up and see how it goes. I use the exact same pump at my local filling station for the fat majority of my fill ups so I should get a good ice on consistency.
My LRA pump makes an occasional surge noise regardless of how much fuel is in there but I just assume it’s doing its thing and ignore it. I’ll run it again after it’s initial s*** off and see what it does.
new personal record!
I think @TeCKis300 has actually tested his main tank to empty, but this is as far as I’ve ever pushed it.
Running the pump after the first shut off definitely gets more out of it.
Of the 47.45, 23.8 went into the LRA (first). Then, the rest to the main - WOT into both tanks from Costco pump.
Running the gas pump after it turns off also risks flooding the charcoal canister, so I only do it if I KNOW that the amount that I just pumped in to the tank is significantly less than the indicated volume on the guages. Again, at least on my 12.5, I can run it dry with the stock pumping configuration delivered by LRA - verified recently when removing the fuel outlet and not losing a drop. But note, I ran it several times after it hit the auto cutoff time to be sure.
I think he meant running the LRA transfer pump again after it shuts off. I’ve done that to figure out how much fuel is left in the LRA, which in my case is about 1gal with the first auto shut off.
I agree 100% about the risk with topping off the main tank. Don’t do that.
I have backed the left rear wheel up onto a curb (fuel pickup is front right) then run the pump with the gas cap off so I could see the fuel transferring.
Ran until the pump was pumping air.
Filled up and only took about 11.8 gal or so.
LRA 12.5.
Here's an interesting tidbit:
I always gas up at the same Costco.
I've been keeping track the last several fill-ups.
Verified LRA 12.5 is empty, filled until auto shut-off, then fill main tank while the LRA settles, then top off aux tank until it clicks off again.
Never takes more than a tenth or so on the top off.
All fill-ups of the aux tank took between 11.3 and 11.8 gallons.
Had to fill up yesterday at a Racetrac station while on the road.
Aux took 12.7 before the first auto shut-off.
Either the Costco pumps are very conservative when counting gallons; or very sensitive to auto shut-off.
I have the same experience, 12.7 at a Super Duper station yesterday; everywhere else is usually just under 12. I question if it is shut off sensitivity of flow volume calibration.
