Tigerstripe40
I am looking at 2 80 series cruisers
one is a 12/92 (93) the other is a 4/94 FZJ 80
Neither have lockers.
The 93 is pretty solid mechanically. No clicking from the birfields, the transmission shifts just fine. It's got 211k on it. The brake light is on, and the brakes are mushy. This is from a dealership.
The 94 is cleaner but needs more work. The brakes are fine. But there is a little bit of loosenes sin the front end (probably needs suspension bushings). There is a noticable CLUNK when going from forward to reverse and back. The birfields are clicking,. and the check engine light is on...
Neither truck has lockers.
Both have cloth seats.
Both trucks have a noticable rumble at idle. The 93 idles at 600 rpm, the 94 jumps from 600 to 900. When the engine gets into higher rpm ranges, it goes away.
Neither is leaking oil or antifreeze. Both are pretty solid considering the milage (211k on th e93, 244k on the 94).
I am going to pass on both. But what causes the rumble? Is that something to be concerned with?
thanks!
Is the lwo rpm rumbnle normal?
thanks!
