Hi!
Im entertaining the idea of swapping my standard 2.88:1 gears in my transfercase to lower range 4,7:1 gears. When doing the math it seems like the original low range overlaps 1st gear high when in 3:d gear low.
If changing to 4,7 gears all low range gears are below 1st gear high (except for 5th gear low which is he same as 1st gear high). Se the excel below sinse I realize its messy to explain.
Is there any drawback to using 4.7 gears (except additional cost and labour) since it seems to produce more uniqe gear ratios? Is it somehow bad to put the transfercase in lowrange and start on 3rd,4th or 5th gear?
Input is appreciated!
//Will
Gear | 1st | 2nd | 3rd | 4th | 5th |
3,954 | 2,141 | 1,384 | 1 | 0,85 | |
T-case Gear 2,88 | 11,38752 | 6,16608 | 3,98592 | 2,88 | 2,448 |
T-case Gear 4,7 | 18,5838 | 10,0627 | 6,5048 | 4,7 | 3,995 |
//Will
