So, I got the BJ42 registered and on the road friday afternoon and took off down the Great Ocean Road a couple of hours later.
Took it for a play on some nice wet muddy tracks yesterday and encountered my first problem.
Everything was going beautifully- 2WD, High 4 and then Low 4...
then there was a fork in the road- straight up the steeper slippery slope, or around then up.
Of course, straight up it was
IIRC I was in Low 4- right at the top, just over the steepest bit, 4 wheels spinning and at about 2/3 noise- something happened, I think it popped out of 4 wheel and the back wheels spun (though I can't be sure)...
I wasn't quite sure what had happened, and trying to go forwards only spun the back. Wanting to take my first 4wheeling a little easy- I reversed down- re-engaged Low 4 and went up the other track 'around'.
Back on the trail and Low 4 was working fine again- but at high torque moments on steep hills I began to notice an occasional grinding noise- sort of like a fast ratcheting sound- when this would happen I would momentarily loose some rate of forward motion (front loosing torque- rear tires spinning?).
The then the trail got really steep, narrow and muddy, no where to turn around... ratcheting noise came more regualarly... not happy
I had to keep going up, so I put tried it in High 4- similar thing, the steeper and higher torque was the problem- and it would pop out of 4W into 2W (but this time without the ratcheting noise),
eventually I tried holding in down in High 4 with my hand and this kept it in 4 until I got to the top of the hill and found a small spot to turn around.
After that it was downhill and I got back home in mostly 2WD with occasional High 4.
No other problems at all, nothing wrong in 2wd, drove great on the highway.... etc.
So, I have been searching here, and I am reading about simple solutions- 'cutting the boot'... putting in new spring, or shimming with washers... bad engine mounts...?
I am a bit lost.
Trying to remain a little optimistic about it
Can anyone shed some light on this?
I am a bit lost.
