Lost compression on cylinder 5
South-East United States
So my 80 died the other day and when I started it up it had a terrible miss. After a compression test and some investigation I found cylinder 5 is leaking and the compression is escaping out one of the intake valves. Are there any other investigative steps to take before pulling the head? I can see both lifters touching the cam lobes at top dead center, and I can push down on them and move the valves. My bore scope won’t look doesn’t look up so I can’t see the valve face. I did run it down the intake manifold to look at the top side of the valves and didn’t see anything alarming. I tried shining a bright light into the cylinder to see if any light leaked past the valve but that didn’t yield any results. Leak down kit won’t build past 10 psi and the draft inside the intake manifold will clearly blow a grill lighter. Any advice would be appreciated
How many miles are on the engine/head? Has the head been rebuilt or the valves adjusted in the past or recently? Any overheating or hard running events of note lately?
If the leak down kit will build any pressure, even a few psi, then it may be hard to see the issue with a bore scope. Larger damage can be visible but the hole will also prevent any build-up of air pressure. The outcome in either case is typically similar and results in needing to pull the head for repairs.
One possible failure scenario is that the intake valve(s) on that cylinder were running too tight and were held open too much, allowing the valves to overheat and burn/erode until they stopped sealing well. Valves have to close securely and for sufficient duration to transfer some heat to the seats and avoid the valves overheating.
Another possible explanation for what's going on is that debris, like a chunk of carbon, is stuck between an intake valve and seat causing it to seal poorly or debris ran through the valve(s) and damaged the sealing surface(s) and/or bending the valve stem so that the valve doesn't sit flush in the seat.
In a situation where you couldn't, or didn't want to, remove the head for a full valve job/etc. you might next check the adjustment on the intake valves for this cylinder to possibly learn some relevant details. For instance, if one of the intake valves is loose then it may be being held open by debris/damage, causing both the lost compression and the larger gap. Conversely if one of the intake valves is too tight then there may be relevant valve face or seat erosion keeping it from closing fully and throwing the adjustment off. Trying to clean the valve/seat in the first case or re-adjusting in the second case could possibly buy you some time and return some compression but that's a long shot and more of a bush repair.
Depending on the engine history, condition otherwise and your goals for it I'd be seriously considering pulling the head for a thorough inspection and then replacement or full repair. Unless you find a clear explanation for what's going on that is reliably repairable it's now time for a full valve job at least.
Valve clearance looks good. Looks like the head will be coming off. The truck has 290,000 on it so it’s probably ready for some valve work. It has also burned oil quite a bit of oil since I’ve owned it. I started removing hardware this evening. I’ll post some photos and keep the thread up with how I’m moving along. I’m just finishing up an overhaul on an old continental flat head engine in my garage, other than that I don’t have much experience going this deep in a motor so I should learn a lot along the way.
Good luck!
I'm guessing you've seen this here but in many cases valve stem seals account for most oil consumption in these engines. I replaced valve stem seals (w a head job) at 225k ish and haven't been close to needing to add oil between oil changes in the 100k+ miles since then.
How deep will you go into the 1FZ? Keep us posted on how it goes.
Follow the procedure in the manual and you'll be fine.
Good luck!
I believe my goals with this project will be to solve the compression issue, address oil consumption, and a new timing chain. Is there specific gaskets/studs typically recommended or just OEM?
You won’t be doing a Timing chain unless you are removing the upper oil pan and timing cover. I wouldn’t be worried about a chain as much as a slipper those tend to have the plastic bits break off.
Looks like you are well on your way, good work.
Yes, I’ve done some reading on that. Figured I will go ahead and replace the chain tensioner slipper, vibration damper, and chain its self. Also all of the gaskets and seals
Anyone know if a puller is normally required to remove the crank pulley? Service manual shows the use of a SST puller with the language “If necessary”
Sometimes they come off easy sometimes they need a puller. I usually use a brass hammer and replace the pulley it’s a wear item in my book.
Well it has been quite a while since the 80 went down. I am finally able to give the vehicle some attention now. The past two days I’ve been pulling it apart and investigating. Last night I confirmed a bad intake valve seat in cylinder 5. I am also going to service the timing chain, and all of this will be done in frame. I haven’t documented as much as I hoped, I have mostly just been focused on the work.
Nice work, I've never stripped a block this far without deciding to take it out of the truck. How was removing the upper pan in place? Would you pull the block if you had to do it again?
Superb time to be replacing your high pressure ps line and transmission cooler soft lines. Looks like no name brand heater hoses on the firewall, would be a great time to replace when OEM or gates green stripe
Will be replacing the heater line and ps line for sure. I am doing this in frame because I don’t want to buy a hoist and stand, lol. It hasn’t been that bad, to get the pan out I just put a bottle jack on the diff and lifted that right side motor mount a bit, then the pan slid right out the back. I think the biggest draw back to not pulling the motor is doing all of this work and not replacing the rear main. If I had the equipment though, I would’ve used it. OEM parts aren’t cheap though and I’m on a budget
On the power steering note, I do have a leak in that area. I think it may be from the reservoir, that’s a common problem right?
