No, it was not on the pickup or 40, (I would have likely rolled, and the 40 still 5 years from being drivable). It was in my MR2 commuter car, which only has 4x100mm lugs. I had changed the clutch this weekend and even though I had cross torqued these lugs with an impact wrench to about 170 ft-lb with this: http://pdf.lowes.com/useandcareguides/879686002796_use.pdf, two adjacent lug nuts came loose, and within seconds the other two lugs failed and the wheel was gone. It was the rear drivers side wheel, I was able to steer on to the shoulder, the car dragged on the lower A-arm/lower ball joint and came to a stop rather quick, I did not even have to break.
My suspicion is that I did not wipe the lugs clean, and oil/grease on my hand could have been transfered to the threads and caused them to slip? Either way it scared the
out of me. I am now going to wipe lugs completely clean with asetone, add a few drops of blue locktite, and torque them to exact factory specs. This is especially important on a 4 lug wheel, I think the 6 lug on the Cruisers and Pickups have enough redundancy to prevent this, but I guess it is really needed, because a 4x4 would have probably rolled with the high CG.
Anyway I am just glad to be alive.
out of me. I am now going to wipe lugs completely clean with asetone, add a few drops of blue locktite, and torque them to exact factory specs. This is especially important on a 4 lug wheel, I think the 6 lug on the Cruisers and Pickups have enough redundancy to prevent this, but I guess it is really needed, because a 4x4 would have probably rolled with the high CG. Anyway I am just glad to be alive.
