Looking for an FJ (2 Viewers)
brooklyn ny
I've always liked them, and now I'm in the market. What are the trouble areas I should be concerned with for a vehicle with over 100k? ...and any other advice.
Thanks,
Carl
If it's in northern climes, check for frame rust or rust hidden with thick paint/undercoating. I'd highly recommend finding a shop that can perform a pre-purchase inspection. It might cost you $200, but you'll have better peace of mind, knowing exactly what's going on. They will test drive it and listen for noises you might not think about. They can also check to see if there are any permanent codes stored in the ECU that might not illuminate the dash lights.
Carl, what model year, automatic, manual, there are 2wd models so…?
Early years (due to price) and preferably manual transmission. NOT a 2wd! ...this is for my 19 year old son - so he stops eyeing my FJ60!
Manual trannies are much less common than autos.
Are the front quarter sheet metal splits not a thing anymore? Mine never has done that in 250,000 + miles, but it happened to some people I guess.
Based on my experience, a high-mileage one wouldn’t bother me, as long as it was decently maintained.
If you can discover maintenance history and the vehicle looks clean you can ask a local shop to check it out, as BMThiker suggests. There are really no major issues in FJ's after the upgrades in 2010 but earlier models can be fine too if you get them checked out thoroughly. Good luck and post up a pic of the one you decide on.
I had a 2010 and adored it. I would only have gotten rid of it to fund a troopy. Get the later year models with the stronger body (research the crumple issue) and the better engine (I've forgotten all the details but it matters to some people, not to others - I think it's the VVT valve timing stuff). That 1GR-FE is a simply superb engine, if it's had regular maintenance 100K is barely a break in.
If this is for a young driver you should consider that driving visibility is horrible. Your son will have much better visibility if you give him your 60. :devil:
