After many evenings in garage after the kids went to bed, it is done!! Well basically (a couple more wires to run).
A few details:
2x2 tube, 1/8 in. wall IIRC.
Slee's spindle.
Spindle attached to frame with 2x4, 1/4 inch thick tube.
Spring loaded pin to keep open.
Spring loaded pin to help keep closed in addition to latch.
Hi-lift can be attached behind the tire. (you can see the base plate for it, I loaned it to a friend for the weekend, therfore, not in the pic)
License plate mount is the OEM one I removed from tailgate and mounted as you see.
Backup light is tapped into OEM back up lights, it is a 100w trapezoid pattern (came as 50w but I put in the larger bulb) .
I can't think of anything else right now. I'll post couple more pics of the pin and spindle in open postion and a side view.
A few details:
Slee's spindle.
