i have a powertrax lunchbox locker that I was going to replace with an Aussie locker today.
A little quick background, I destroyed my pinion and had to run my rear axle differential with a powertrax installed without oil to get my rig off the trail and home. I replaced the ring and pinion and did a total axle overhaul. I used the same powertrax locker upon reinstalation.
In testing my powertrax function last week, I put my cruiser on some loose dirt and stomped the skinny peddal. Only one wheel would spin which to me suggests that the locker isn't working. also I tried to climb up a ledge w/ my cruiser and I was unable to do it, just one wheel sat while the other spun. If the locker was working properly wouldn't both wheels spin in the loose gravel when i am purposely mashing on the gas?
Also i have been noticing alot more clunking from the powertrax since its reinstalation, I know that they are loud by design, I guess I have tslked myself into the fact that although it looked ok at the time of reinstalation the locker was damaged from running for an hour without lube.
I have a new aussie locker at my house, it is nearly an identical unit to the powertrax/lockrite designs.
Is my assumptions about locker function correct? both my wheels should break free on loose gravel/grass when I am purposely trying to spin them shouldn't they?
Thanks
Drake
Thanks
Drake
