This simple mod will appeal to the part-time guys.
I wanted to have control over my lockers without engaging the center diff lock or 4WD in my case being part time.
Go to the Dif lock ECU in the passengers kick panel. Locate pin 15 (pink/ black tracer on a '96)on the gray connector plugged into the ECU. Cut the wire, terminate the harness side of the wire and ground the connector side.
The center diff light and button still work the same but now you have control of your lockers at anytime.
Sorry I dont know how to post a picture of the gray connector showing pin location.
