Ok this is a strange one caused by multiple unlucky circumstances. My driver door actuator has been intermittent lately. I replaced it in 2018 but it appears to be failing again. To be honest I don't recall ever testing the mechanical key when I replaced actuator motor - I wish I did! Truck is 2013 LX.
I pulled the car in the garage today and left it running with hood up so I could check oil. I got out with the key in my pocket. When I walked back to the truck the driver door half opened but would not open all the way. Car would not lock or unlock with either FOB. I tried the mechanical key and it did nothing. I then pushed door fully closed. Truck is running now, doors locked and both fobs are with me. I disconnected battery and truck is still running fine
I pulled an ignition fuse to at least kill the motor.
Truck is now electrically ON but not running. I cannot get inside. I've tried disconnecting battery, pulled all the smart fob fuses I can find and even disconnected the ECU. Apparently computer thinks a door is open and car is ON so the FOBs don't do anything. I was hoping to reset ECU so I could use FOBs but no luck.
Is my only choice to call a locksmith?
