I have been working on getting the oil pressure gauge to operate properly in my 1991 LJ78 with the 2.4 L diesel. I have jumped the leads going to the gauge, which causes the gauge to peg, which I understand means the gauge itself is OK. I have replaced the sending unit twice and I get no change. When everything is together and I turn on the ignition all the gauges except the oil pressure bump up to a minimum level. When I start the motor all the gauges act appropriately, except the oil, which doesn't budge.
Can anyone think of something I'm missing (which wouldn't be saying much! I'm OK with a wrench, but I'm no technician)? I am confident that I have oil pressure, for one thing, because the engine hasn't failed, eventhough I have been running it a bit. Oil drips out of the hole when I remove the sensor and I have (carefully) run a stiff wire into the hole with no resistance. I will appreciate any ideas you can throw at me. Thanks
