Ok I have a bit of a starting gremlin with my 1990 lj78 (2lte). In the morning my truck starts and runs fine. I drive to work, I am here 8-10 hours. When I go to leave the damn thing takes about 6 minutes and about 50-60 cranks to get it started. Weird right?
Little bit of back ground info.
My truck came with a aftermarket "Wilson" switch installed by the PO
This problem stemmed after I replaced my injectors 2 weeks ago, I grounded out my glow rail when I put everything back together and fried my fusible link wire that goes to the battery... Not knowing what this wire was I "upgraded" it with a larger wire and tried starting it again. Well all this did was fry the wires going into the glow plug relay (the round one behind my battery). So I have since replaced that plug, changed the fusible link back to the way it was and sorted out my grounding issue.
Do you think I have done damage to my stock relay? I am considering picking up a 100 amp relay from princess auto and bypassing my stock system all together. I'd switch the glow plugs on manually with a momentary switch. Thoughts? Thank you in advance! -M
