Hi all,
I'm one week in on a roadtrip around the USA and now that I'm at a high altitude (wyoming-utah) 2L-TE in my Prado is giving me grief - higher than normal EGTs on the hwy and I'm basically unable to go up any decently sized hill without overheating.
Basically I'll enter a hill doing 90 kph or so and hold the egt at or just below 1000f and the car will gradually slow down up any hill and I'll downshift to the point where I'm in 2nd going at about 50 kph, and by that point there's not enough air flow into the rad and it'll overheat. Pretty ridiculous.... Air temp is also not hot, 10-20°C. I've had no problems of this sort in Ontario (basically all sea level) but we also don't have hills of this calibre near me.
Research so far has lead me to guess that my problems are twofold-
1. The e-fan that the previous owner installed doesn't pull enough air at low speeds when the engine is under load (-> overheats when going slow)
2. There is no altitude compensation (again this is my guess - I could not download that Denso manual) on the 2L-te which is causing it to run rich and hot at altitude. In Wyoming where I was, I was around 2500m altitude, so the atmospheric pressure would be about 4 psi less than sea level. If the engine is seeing 10 psi boost and fuelling accordingly but there's really "6 psi" of air going into the intake I could understand why the EGTs are so high all the time.
So, I understand there's a bleed valve mod I can install between the boost line and the boost sensor (I've already tried to replicate this by poking small holes in that line near the sensor... I think it has helped, but not solved the issue) but other than that, any suggestions or spiritual guidance? Preferably something I can do "in the field" as I'm quite far from my workshop.
Or is there a bigger problem with my car? This seems pretty absurd that the car barely works at high altitude, and I couldn't find reference to anyone else having similar issues....
Thanks,
Eugene
Currently near Ogden, UT
(Background info-
2L-te LJ78, 3L head swap reportedly done
Head is not yet cracked (I keep checking)
Automatic
33" tires, 2" lift
Snorkel and cheesy looking k&n filter, EGR delete
2" exhaust (that's all I could scrounge at the last minute)
Stock rad with e-fan
Roof box and a ton of crap in the back of the car, maybe 4-500 lb? )
Thanks,
Eugene
(Background info-
Automatic
33" tires, 2" lift
