Hey guys, Im going crazy trying to figure out whats wrong with my truck. I have a 99' LX with 144,000 miles. About 4 weeks ago my car was idling very rough and then my CEL came on and I got P0171 & P0174, which is system running lean (vacuum leak?). I read tons of stuff here and thought it was either the mass air flow sensor or maybe the Throttle Body Sensor. I cleaned the throttle body and MAS, I check over the whole engine for vacuum leaks (did not find any) and I replaced the spark plugs and the fuel filter and air filter. The CEL never came on again and the truck ran much much better but now the engine was idling really high, between 1000-1500 depending on the day. I checked with Slee and another mechanic and both said that I its really hard to diagnose the problem without codes currently happening.
Yesterday my truck seemed to be idling a at 800 and very rough again, and in the afternoon I all the sudden had my CEL blinking like crazy. I also seem to have a loss of power, but could still drive fine, no noises or anything strange. I went straight to the auto store and had them run the codes. I had 9 codes!!!
P0153 Circuit for O2 sensor Bank 2 sensor 1
P0150 O2 sensor Bank 2 sensor 1
P0133 Circuit for O2 sensor Bank 1 sensor 1
P0130 O2 sensor bank 1 sensor 1
P0300 Random/multiple cylinder misfire
P0302 Cylinder 2 misfire
P0305 Cylinder 5 misfire
P0304 Cylinder 4 misfire
I have an ohm meter so I can test the coil packs today, thinking thats what it is but wouldn't just one coil pack go out at a time? Also I have a small exhaust leak, but I wouldn't think that would cause all this trouble. Maybe I need to replace MAS or TPS sensor? Im guessing my problem a month ago and this problem are related but the P0171 code did not come on this time. I also replaced 2 O2 sensors about 3 years ago, but i can't remember which ones I replaced.
Thanks for any help in advance, Ive dumped a ton of time and money into this truck in the last year, (timing belt, starter, water pump, tires, brakes, shocks) and Im getting really tired of spending my weekends in the garage and putting money into this thing so this recent problem is really irritating!
