lighting question
Do the lamps that are not working have any glow to them at all? Have you swapped the lamps from to the working set to the one that does not work?
Look at the wiring diagram on the ballast and check it. Also pull on the wires that plug intio the ends. I have seen the fixture lamp ends wired wrong from the factory. If all checks out I would agree with others on a bad ballast.
