- Thread starter
- #21
In those pictures did you do anything with the front, or just the rear spacers? I really like it.
corleykj said:Man that looks awesome. And very functional. What did you do for your front torsion bars?
Replaced them with low mileage OEM and raised the front to 2.25". I recently installed 30MM spacers ontop if the 866 and increased front lift to 2.8".
What problems are caused with lifting besides CV leakage? What parts are "required"? I'm confused as I'm running 100% stock suspension (minus shocks) and my truck sees
more abuse on the street than 99% of the rigs do offroad in the 100 section
corleykj said:Ok, you used low mileage Torsion Bars that were original equpment, and 866's in teh rear with spacers and have 2.25" in the front and 2.8" in the rear. Again, sorry to be a bother, but can you send me pics please or post some?
Thanks.
pfran42 said:Alignment issues. Many have reported this. What you consider acceptable might not be considered the same by others. Also, you need a cv boot solution. As you go up in height, many purchase UCAs, bump stops, diff drops, sway bar extenders, panhard rod extenders, 4.88 gears, spacers, fender trimming and on and on. What I am saying is that every mod to raise height comes with it's pluses and minuses. Granted, you havent done a lot to your suspension but I can assure you as you start you start adding things, you would best be served by adding other things to correct the things you added in the first place.
866 with 305 (same diameter as 285/75). Also equivalent as stock springs with 30MM spacers.
)I would crank your factory tbars, install new shocks and buy some OME 865 coils. This will give you a nice 2" lift with a very close to factory ride. With this setup you don't need a diff drop and you don't open up the can of worms Pfran refers to once you go bigger.
Here's my '03 Land Cruiser with 1.5" of lift (rear coil spring spacer and front torsion bars cranked to match) with 275/70-18 BFG AT's. 21" from center of hub to fender lip. Anything greater than that and I get torque steer and the shocks top out. I plan on adding Air Lift bags in the rear before a few family trips this Summer to help the stock springs keep things level.
https://forum.ih8mud.com/100-series-cruisers/91953-mud-100-series-photos-thread-129.html#post6052800
