Lift install help
Colorado
Hi every one
Im installing a lift and need some help. I'm on the passengers side and can't remove the rear section on the torsion bar from the mounting bracket. Any suggestions on how to remove it? I have tried punches hammers and got out the BFH with no luck.
Hi every one
is there any pressure on the TB? If not I would use some heat.
Got a torch from a friend finally got the lift done. Just need to get the alignment. Then the start of next project of replacing the bumper. Looking at Slee or BIOR.
I have a BIOR rear bumper ordered. :)
Be very glad you were able to get it off with a torch. I was late to CM last year because of the same issue. I had to cut the old torsion bar and drill a hole in the back of the bracket to punch it out, and this was after a lot of torching...
What do you have on the front?
I had the saw standing by if that failed
TJM on the front
