Lexus LX470 Auto Window Goes Up And Then Down Immediatly (6 Viewers)
Under my cruiser
Website
www.youtube.com
My car's rear left window auto function isn't working properly. When I pull auto up button, the window goes all the way up and then comes down automatically a little bit and stops. How to fix this annoying problem?
I did try some of the tricks by holding the button up for few seconds and down for few second to reset the pinch sensor but no success.
I have this same problem on a 2004 LX470 on the Passenger rear window. I didn't find much on a search here. Did you ever find any solutions to your issue?
i plan to try this
This has something to do with the pinch protection feature of the window. I think I had the same issue and I cleaned out the track of the window and it fixed it. Blow some air, shoot some silicone lube, and then wipe down clean. Run the window up and down a few times and see if it helps.
You need to remove the regulator from the motor and strictly follow the procedure in the FSM.
