great work with this conversion. any conversion is a lot of work. But to say this I5 will run around the 1fzfe is a littte generous. the I5 in the h3 made only 220hp until 2007 when it made 242.
We did get the 3.7L, in 2007 H3 trim, so it's spec'd at 242 HP. In accordance with GM practice, I think that's now spec'd against the newer SAE guidelines, so the difference relative to the 3FE's (155) and 1FZ's (212) numbers are probably a little greater... We haven't gone nuts with mods-- a K&N Cold Air Intake and some timing tweaks are about it-- so probably aren't getting much more than 250HP out of it. The VVT makes it a pretty flexible motor, though, and it will pull hard up to its 6300RPM redline-- makes most of its torque down to 1750, yet with the cam-phasing can keep its TQ output up to 6000+. I think the FJ80 redline is at 4500, and my FZJ80 was 5000?
Having owned FJ80s, an FZJ80 (as well as FJ60 and FJ40) there's no question that the FZJ80 was the most powerful and refined of the bunch-- they are genuinely great trucks and the 1FZ is a super motor. But, in the FZJ that 212 HP was pretty taxed moving a 4800#+ curb weight truck. I don't know that "runs circles" would be the right phrasing, but the Atlas power/weight in an FJ80 is substantially better.
I do know that on the same (long) grade I drive all the time (over 2000' elevation gain in less than 5 miles) the stock FJ80 was max'ed at 48MPH, the FZJ80 would struggle to hold 65MPH and this Atlas FJ80 will easily blow past 75-- which it will readily hold in 3rd gear with the higher revs it can run to.
Not all of this can be explained with 40 extra HP (even new-SAE HP). As Jule pointed out, though, a lot of it's weight. We're likely 400-450 pounds lighter than a stock FJ80 (which TLC4x4's site says had a curb weight of 4595). Relative to the FZJ80, the disparity is even greater-- with the added equipment on the FZJ, its weight (again, according to TLC4x4) went up to 4760. So, this Atlas FJ80 could be 600+ lighter than an FZJ--- that's getting pretty substantial, especially with a 40HP power advantage.
So, by most of the objective power-weight criteria, the Atlas truck "should" be quite a bit quicker and faster-- The hill-climb test shows it able to hold a lot higher climb velocity-- that likely translates into the usual metrics like better 0-60, 1/4, top speed (Although I suppose a forum like IH8MUD is a strange place to talk about trap speeds.) etc.
So, for what we built the truck to do-- we're pretty happy with it. The reality, of course, is that it's not nearly as well-proven a powerplant as either Toyota mill-- so the Atlas could blow up tomorrow and the 3FE's will continue to post 400,000 miles before needing work.
The weight difference is the big eye-opener--- 600 pounds is a lot. When we build the Duramax FJ80 it will be funny if IT ends up being lighter than a stock FJ80. That would be twisted.
TT
The extra
