I just wanted to summarize this build this far:
Purchased with:
Boost, temp, and EGT gauges
Non functional hub locks
Engine with cracked head
Clogged rad
Improvements/maintenance
2.5” exhaust (2016)
Replaced with used engine from a surf (2010)
New rad, water pump, belts (2010)
Manual hub conversion using spacers (2018)
Exhaust front to back (2010, 2014)
Front axle service and brakes (2015,2018)
Rear brakes and seals (2014)
Rear diff housing removal, new gasket, and prop shaft seal (2014)
Steering flush (2016)
EGR delete (2016)
A/C delete (2016)
New air filter (2018)
New glow plugs (2016)
New turbo (2018)
Gasket on injection pump replaced in situ (2017)
Water/air intercooler (2017)
Gas turned up half a turn(2017)
Rear quater panel body work and paint + bumper delete (2018)
Remanned upper rear door hinges (2018)
3” exhaust with 3” custom downpipe, magnaflow muffler, with side pipe (2018)
Tridon high flow thermostat (2018)
Rad flush (2018)
Next up
1) 3” inch exhaust with straight pipe and magnaflow
2) rad fan upgrade to fan from 1992 pickup v6
3) rad flush
4) high flow through thermostat
5) turn up gas a quarter more (and trick to computer to allow boost >14psi by installing little bleed valve between the intake manifold and the boost sensor to bleed off some of the boost????..advice from gtssportcoupe)
I think thats it for now. Much thanks to ih8mud and all of you on the board for teaching me how to do this stuff. Its really the best hobbie/obsession I have!
Lee
