Those aren't bright enough
show me some real LED during daylight
Great writeup. I love the engine bay lights.
FYI, I have halogen rear running lights, brake lights, blinkers and reverse lights. They provided an immediate and easily noted upgrade in brightness for all the lights back there. While these don't provide the instant on of an LED brake light, it is worth noting that they've been in there for some 150,000 miles without a blip. If you're behind my truck at night at a stop light, you'll definitely feel like you're behind a school bus or similar vehicle with upgraded rear lights. Slightly annoying. In poor conditions, they stand out however and my family and I are often driving in foul winter weather on isolated roads so I felt it was a needed upgrade.
Why are these super bright LED's burning out, BTW? Anyone know? I thought one of the chief LED advantages was long life. Are they overdriven and have no control circuits?
The stock 80s already have the LED third brake light, but I'd sure be interested in a high output LED brake light bulb - suggestions?
DougM
George's LED's can be found at www.taskled.comI keep seeing "Georges LED's"...but where do I find this George...or his website?
Thanks~!
I like the hood lighting-- I'm planning to do something similar, but instead of hard-mounting the LEDs, I was thinking I would mount one onto a strong magnet, then I could move it to where it is needed. Just have to figure out how best to do the wiring so that it doesn't get in the way.
George,
Thanks for checking in! Do you have a "George" sensor on your computer? Heh.
Hey, nice reply - the Crees are indeed good stuff. I've recently purchased a few handheld Cree lights. If you're still out there, do you have any recommendations for a plug and play quality brake light solution for the 80? I like the instant on aspect, but would only bite if the product is brighter than stock and will last as an LED solution should.
Thanks!
DougM
I too haven't found decent drop in bulb replacements for the stock brake lights.
cheers,
george.
I've installed this 39mm 6 LED festoon light in the map light of my Tundra. It is brighter than the incandescent 39mm festoon bulb. It puts out about the same amount of light as George's 1Watt Luxeon LED in the dome light . George's LED is 30mm while this LED is 39mm.
Hey George, i have your dome lights and map light already. Any chance of you making another pair of Kaymar tail lights? I just installed dual spares on it and the tire semi-blocks the stock tail lights. Making the Kaymar brake lights a bit more brighter and a running light built in would be a nice plus for us. We can use all the tail light we can get.
