Until you isolate the suspension - front to rear - there's no way tell where the lean is originating... well, unless you just start replacing parts, e.g. springs, T-bars, etc.
Let's say a truck was leaning on the Left Front by 1". You could "fix" that by cranking the T-bar 1" on the Left Front. The Front would now be level. But, if the problem wasn't the Left Front T-bar... the Rear would now be low on the Right Side... by 1".
Isolating each end is tough. I had a CJ that leaned by 1" - Right Rear. It seemed like it HAD to be a sagging spring. These were new 4.5" springs - the best available (Rubicon Express). So, it wasn't likely... but possible. To figure it out, I swapped the rear springs left to right... The sag was still there - 1" on Right Rear. Not the rear springs.
With a floor jack, I raised the frame at the sagging corner, until it was level in the rear. Now, the Front Left was down by 1". Not good. I swapped the front springs Left to Right. No change.
After inspecting all spring mounting points the culprit was identified... a twisted/bent frame. The "Jeep Lean" is a known thing. AMC actually had a TSB for it - putting shims on the spring perch equal to 1/2 the amount of the lean... to split the difference, e.g .putting some of the lean in the front and some in the rear.
I'm not suggesting you have a bent frame - it's a Land Cruiser, not a Jeep. CJ frames were poorly made and not strong. I'm only suggesting, that you've got to consider all four corners when chasing out of level suspensions.
