Just had a look under the bonnet and noticed puddles of fuel around the injectors and believe it is leaking around the rubber packing washer. Anyone else had this problem and what does it involve to repair? It's a 12ht factory turbo.
Cheers
Cheers
If it's from the leakage pipe I believe each injector has two soft washers (copper or perhaps aluminium) either side of its leakage-pipe-banjo. And you should be able to stop such a leak simply by tightening the offending securing screw/bolt.
If it's coming from a high prerssure connection, then again I'd just check them all for looseness.
I'm not familiar with there being any rubber there .... unless the leakage-pipe-banjo washers are now rubber-coated.
