I just rebuilt this gearbox a month ago. I thought I did a stellar job, having never done one before. All the parts went back together as expected and I tried to be very careful in reassembly as to not damage any of the teflon seals. On the first 2 weeks of test driving no leaks at all. Now it is leaking out of the adjustment bolt at the top and I am really hoping the answer to this leak is to somehow tighten or readjust the adjustment bolt, not take it all apart and tear it down on the bench again to rebuild a second time, but better. When I first noticed it leaking I was able to tighten that top nut (17mm) down tight and hoped that stopped it. It is still leaking after I cranked it down hard so I need to figure something else out before I tear it out and start anew.
I ask here if anyone has experience with this type of leak before I start messing with the adjustment screw and bolt throwing the gearbox lash into disarray while I try to stem the flow of ATF being pushed out the top without taking this all apart again.
Important for context, I also just as part of this rebuilt changed out the power steering pump to the Saginaw so there is more pressure coming into the gearbox than there was before.
